Date/Time: Mon, 24 Feb 2025 03:40:28 +0000
Pull/Stack in Number bars calculated values
View Count: 717
[2021-03-02 13:05:50]
Ben A - Posts: 123
Please can you advise how I can set the number of levels recorded in the pull/stack columns in the Number Bars Calculated Values 2? Is this set to same setting as DOM?
Also, is there a way for me to do a summation on this study but ignoring minus values (only summation of positive values)
Thank you,
Date Time Of Last Edit: 2021-03-02 14:15:07
[2021-03-02 16:25:39]
John - SC Support - Posts: 38116
The data that is in the Numbers Bars Calculated Values 2 for the Pulling/Stacking is the same as what is in the DOM. So the only way to control the number of levels is to limit the number of levels for Market Depth in the DOM. Refer to the following setting:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
There is not a way to change the summation of the study to just include positive values. You would have to program that yourself. Refer to the following function for the data:
ACSIL Interface Members - Functions: sc.GetBidMarketDepthStackPullValueAtPrice()
[2021-03-02 17:00:50]
User542430 - Posts: 50
Under Trade>Chart DOM Settings, there is a setting for the Pull/Stacking that might give you what you need.
