Date/Time: Thu, 19 Sep 2024 21:35:43 +0000
Vol. at Price Chart
View Count: 969
[2014-02-27 19:34:41] |
User17781 - Posts: 1 |
I have been using p@v on sierra for 3 yrs. Start charting today, vol. it is off the chart, but still getting the price on the chart. I have done everything that i know how to get the vol. back onto chart. NEED HELP TKS.
[2014-02-28 09:35:57] |
This is not clear for us. Go to Chart >> Reset Scales and see if that solves the problem. Otherwise, we need you to post an image of the chart following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image And then point out specifically what in the chart is not correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-28 09:36:17
