Date/Time: Fri, 18 Jul 2025 22:46:23 +0000
denali not activated any longer
View Count: 578
[2021-03-02 01:53:55] |
User68acg - Posts: 17 |
AS already posted I have been using Denali for some time but recently had to change the routing to cqg and that was all dandy but last night it all just stopped and I get a message that symbol is unknown etd realtime data not allowed etc.. I just noticed that my Denali is no longer activated. Why is this? Whats happening? I can no longer trade and no longer have live data. I can use cqg to get live data on TradingView. Thanks Andy |
[2021-03-02 15:13:12] |
John - SC Support - Posts: 40963 |
We do not see any issues with your setup, are you still having a problem getting the Denali data?
[2021-03-03 06:34:37] |
Make sure you are using the correct symbols. Translate them with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service If you still have an issue: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-03 06:34:50
