Date/Time: Mon, 24 Feb 2025 03:54:16 +0000
Sierra Chart with Advanced Features (Service Package 5)
View Count: 602
[2021-03-01 22:00:33] |
Habakuk2020 - Posts: 10 |
Hello, I am desperately looking for a list of the symbols I can trade with my Service Package5. I can't find a list of the symbols I can trade with CQG or with Package5. I use the broker AMP and of course SierraChart as a trading platform. I look forward to an answer, thank you in advance. Best regards Fingerlos Mario |
[2021-03-01 22:21:36] |
John - SC Support - Posts: 38116 |
First, the symbols you can trade has no relation to the Service Package from Sierra Chart. Second, if you are using CQG for your Order Routing, then you would need to check with them (or your broker) as to what symbols you can trade. They definitely support the CME Group, if that is the main thing you are looking for. Once you know what symbols you want to track/trade, then you would need to setup your Sierra Chart with the appropriate data feeds. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
