Date/Time: Mon, 25 Nov 2024 19:44:12 +0000
chart value window pop up
View Count: 1030
[2014-02-27 17:03:07] |
User73009 - Posts: 12 |
When I put my cursor over a bar or candle i do not get the information of that bar or candle on my chart value window. How do i get them to communicate again?
[2014-02-27 17:03:59] |
How do i change the font on the chart value window to make it bigger or smaller in size.
[2014-02-27 17:59:18] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
