Date/Time: Mon, 24 Feb 2025 01:25:19 +0000
Standard Deviation Bands Study Base on LOW - bug but i think its because of false print.
View Count: 436
[2021-03-01 19:58:56]
GravisHTG - Posts: 306
My time zone to chart is NY time
This picture is for symbol MORF , time between 14:17 and 14:31.
You can see that the band band on LOWs are giving us way too much range compare to the Band base on HIGH.
I just check , the same happened on any Moving average I select + its a 2.0 deviation.
I can see from my chart , I have the problems on 1M chart , 10s charts. Maybe other time frame.
And this is not an Isolated case , it happen often , Only on base on LOWs.
Date Time Of Last Edit: 2021-03-01 20:02:19
imagestdDEV problems.PNG / V - Attached On 2021-03-01 19:58:41 UTC - Size: 28.08 KB - 202 views
