Date/Time: Mon, 24 Feb 2025 03:38:20 +0000
MBO on chart
View Count: 1206
[2021-03-01 19:17:15] |
TradingMarketProfile - Posts: 120 |
hello, i have package 12 now, i added MBO colomn on the DOM on chart but nothing in therer can you help please thanks |
[2021-03-01 19:49:46] |
Follow the instructions on this page: Market By Order Data And update Sierra Chart to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-02 13:22:02] |
it's ok, working thanks but now when i want to set minimum of order, it's not working (see screenshot) |
[2021-03-02 15:41:33] |
At the top left of the Symbol Settings window you need to enable Use Custom Symbol Settings Values and reconnect to the data feed after: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
