Date/Time: Mon, 25 Nov 2024 19:30:16 +0000
30 sec chart
View Count: 1090
[2014-02-27 17:00:07] |
User39772 - Posts: 311 |
When i select 30sec chart (data feed delivers Tick/Tick basis) what I see is actually a 1m chart.
[2014-02-27 17:36:47] |
This is because the historical data is 1 minute. You need a tick by tick data configuration: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
