Date/Time: Mon, 24 Feb 2025 04:03:53 +0000
Discount on Data
View Count: 589
[2021-03-01 18:49:15] |
Adam Schwartz - Posts: 81 |
I used to receive a discount on data as I am using both the denali exchange data feed and the other one that you offer. This used to show up as a rebate in the recurring services section when I log in. The discount is not showing up anymore. Has this been changed or is it still running? Please clarify. Thanks.
[2021-03-01 21:17:12] |
John - SC Support - Posts: 38116 |
This is no longer in place, as we have reduced the price of the Denali Exchange Data Feed by $10.00 when you are using Package 10, 11, or 12, which will be required soon when you are using the Denali Exchange Data Feed. Therefore, you should make the switch to Package 10 when you have a chance, and let us know when this is done so we can credit you for the Denali Exchange Data Feed fee that you have already paid. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 21:27:38] |
I see. My license is still valid till June, I have paid for up until then. I just switched to package 10 (6 month option) even though there were not enough funds to do so it still let me? When will I be charged for the license renewal? Will this be June still? |
[2021-03-01 21:56:55] |
Your account is now on Service Package 10 with an ending date of: | Ending Date: 2021-05-07 |
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 21:57:02
[2021-03-01 22:00:03] |
a) where does the credit for denali show up? b) does this mean I lose a month? Since my previous license was supposed to end at the start of June? and package 10 now starts beginning of may? I know you are busy and apologize, it's just a bit confusing. |
[2021-03-01 22:15:19] |
When you switch packages, it just recalculates the amount of time available to you. Switching to a higher-priced package will reduce the number of days (which is what occurred in this case) and vice versa. Package 10 is now your package. It does not start in May, it is the package you are now using and will renew in May. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-01 22:25:23] |
Ok I see thanks, makes sense. Last question....does that mean the denali feed I paid for today gets refunded/added to my services balance?
[2021-03-01 22:37:53] |
Yes. We have taken care of this for you.
