Date/Time: Sun, 02 Mar 2025 20:51:27 +0000
service packages
View Count: 643
[2021-03-01 16:19:06] |
User633898 - Posts: 28 |
Hi, Can you please enlighten me the difference between service package 3 standard and service package 11 sierra standard plus denali? What I need is realtime data feed for NQ and HSI only. Thanks |
[2021-03-01 18:41:08] |
John - SC Support - Posts: 38292 |
You will find the differences in the packages outlined here: Description of Service Packages and Pricing: Packages If you need data for NQ and HSI, then you would need to be on Package 10 or 11 (for the Denali Exchange Data Feed for the NQ) and also use the Sierra Chart Exchange Data Feed for the HSI (Hange Seng Index). Refer to the information here for the Denali Exchange Data Feed: Denali Exchange Data Feed And refer to the following for the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-23 02:19:04] |
Hi, Can you please advise if Sierra support charting for stocks listed on HKSE and SGX? Thanks |
[2021-10-23 16:55:30] |
Sierra Chart does not provide this market data. However, the supported Interactive Brokers trading service does: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
