Date/Time: Mon, 25 Nov 2024 21:48:47 +0000
Spread and Option Charts with CQG
View Count: 1677
[2014-02-27 15:29:50] |
User20665 - Posts: 5 |
Hi - I am having trouble pulling up charts for spreads [simple spreads for example SK14 - SN14] and all options using my CQG service. I have talked with the IT people at my broker's office who have been troubleshooting the issue from there side and have confirmed that all the data I need is available yet the charts will not populate. Please help as this has been an ongoing issue since I started using CQG feeds. Thanks, Garry |
[2014-02-27 18:38:56] |
Sierra Chart does not have spread or option symbol support when using CQG and there are no plans to offer this right now. Adding support for this would be an extensive amount of development. If you are interested in just charting spreads, and not trading them it is possible to create simple spread charts by using the Difference (Bar) study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-06 17:36:27
[2014-03-05 20:13:52] |
Thanks for the response. Am I able to use this study to take the difference between two different charts? For example, May Corn - June Corn? Thanks |
[2014-03-06 17:36:04] |
Yes. The Difference (Bar) study can be used for this. Here is the correct link to the study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s3 The one given previously was not correct. It has been updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
