Date/Time: Mon, 24 Feb 2025 00:44:13 +0000
Attached Orders on new entry when already in a trade
View Count: 397
[2021-03-01 14:58:15] |
User98657 - Posts: 336 |
I'm noticing something strange with respect to attached orders. Assume I've entered a position and I've gotten some targets off. The market retraces, and I enter again, while I still have remaining positions using the same saved order configuration with attached orders. For some reason, when I enter the second position, the attached orders are not being included. Is there a setting, or reason for this? |
[2021-03-01 18:07:12] |
John - SC Support - Posts: 38116 |
The first thing to check is if you have Scale In enabled, and if so then are the attached orders that you already have are being increased in their quantities? Refer to the information here: Attached Orders: Scaling In The next thing to check is that the Attached Orders option is enabled (and attached orders are defined) when you are placing the second position. Refer to the information here: Attached Orders For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
