Date/Time: Sat, 21 Nov 2026 01:12:10 +0000
Footprint/Numbers bars chart not allowing time change
View Count: 790
| [2021-03-01 14:15:55] |
| User255336 - Posts: 28 |
Good morning - I have a chartbook that contains 3 footprint charts with numbers bars studies. If I change time frames from say a 30 minute to a 60 or 240, it keeps reverting back to a 5 minute chart. Even if I manually change the number value in the Chart Settings, it's forcing back to 5 minute. If I go into the chart settings, it's forcing the session times to start from 00:00:00 and end at 23:59:59. No matter what settings I input, it's reverting back after I click Ok. Any idea why these settings or time frame changes are not sticking? I frequently switch back and forth between the 240 min and the daily historical, so I wanted to duplicate the chart, and create a dedicated daily, however it's forcing me to use a 5 minute. I have tried to delete and download all data - same results. Sierra build 2234. Thanks in advance. EDIT: I seemed to have resolved this by removing charts from this chartbook that were copied from another chartbook. Not sure why the conflict. Date Time Of Last Edit: 2021-03-01 14:21:54
| [2021-03-01 15:25:40] |
In the future, refer to: Unable to Change the Bar Time Period for Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
