Date/Time: Mon, 24 Feb 2025 03:29:56 +0000
No Order Routing with Eurex Data
View Count: 633
[2021-03-01 09:32:05] |
User956379 - Posts: 27 |
Ladies and gentlemen, as soon as I have entered an order in a Eurex market, I get an error message. I attached the message. Can you help? Thank you very much
Attachment Deleted. ![]() |
[2021-03-01 12:44:14] |
It looks like your trading account is with Dorman and they do not support trading EUREX over TT (Trading Technologies). If you want to trade EUREX you need to ask them to move your account to CQG instead of TT.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 12:44:34
[2021-03-01 18:27:27] |
Thank you. I switches my Orderrouting at Doorman from TT to CQG. If I try to connect the Tradeservice from TT to CQG there ist a Message: Trader is not enabled to use SierraChartData. The collegue from Dorman told me, that it is possible to use the Denali Datafeed with Orderrouting from CQG? |
[2021-03-01 20:54:17] |
John - SC Support - Posts: 38116 |
It sounds like you need to let your broker know about the specific Enablements that are described here: CQG Trading Platform Service: CQG Account Requirements For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-02 17:28:11] |
User359698 - Posts: 17 |
I've encountered the same issue. Would another but similar workaround be to use the Dorman account with Sierra-TT service to primarily route CME orders and the AMP account with CQG service ($10/m + $0.10/side) to primarily route Eurex orders both obviously using different installations of Sierra Chart? Related to this process: Using Multiple Data and Trading Services at the Same Time If I placed orders to CME on the Dorman/Sierra-TT service and AMP/CQG service in the same month, would I need 2 systems activated for the exchange (CME) in a given month? Are there any sort of extra data fees to be paid to set this up other than the $10/mo CQG service? |
[2021-03-02 18:15:52] |
You could do what you are suggesting. You would not need any additional data/service connections in order to do this, as long as both installations are on the same computer.
