Date/Time: Mon, 24 Feb 2025 00:03:40 +0000
Urgently Need to change Package for MBO
View Count: 524
[2021-03-01 02:55:01] |
kam2001 - Posts: 79 |
Hi, Previously I was on Package 5 and had Eurex exchange service activated, Last month when the new data feeds with MBO were released, all I did was activated Denali Data feed and started receiving MBO and extended Market Depth levels. However as I was on Automatic renewal, this month my package went from 5 to 11 and I am not receiving MBO. Could you please advise or update my package for this month so I get to see MBO info. Thanks
Date Time Of Last Edit: 2021-03-01 02:56:15
[2021-03-01 03:01:46] |
Currently we see that your package is set to package 12. We are checking on the market by order issue for EUREX. This may be a problem on our side. Just give us about 20 minutes.
[2021-03-01 03:17:11] |
We have identified the problem. Just give us about another 15 minutes or so to get the market by order data working again for EUREX.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 03:17:32
[2021-03-01 03:49:20] |
Works now - Good Job, Thanks
