Date/Time: Mon, 24 Feb 2025 04:23:05 +0000
Erroneous position in SIM
View Count: 507
[2021-03-01 02:50:10] |
58LesPaul - Posts: 429 |
I open my SC this evening and it shows a long position but Trade Activity Log shows all orders closed. I flatten the position and then Trade Activity shows I am short. I delete the position in Trade Activity log and then the open position shows back on the chart. Now when I do put in a position it shows that the erroneous trade has been completed and shows a big loss instead of a gain. How do I clear this permanently? Thanks |
[2021-03-01 03:15:51] |
I open my SC this evening and it shows a long position but Trade Activity Log shows all orders closed. We think there is a problem regarding inconsistency with the Order Fills Start Date-Time. Refer to:Trade Activity Log: Removing Duplicate Symbols from Trade Statistics for Charts Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 03:16:37
[2021-03-01 11:04:26] |
All of the settings for each chart are the same and I only have Chart Trading activated for 1 chart.
[2021-03-01 12:57:27] |
We need to know how precisely you come to this conclusion: I open my SC this evening and it shows a long position but Trade Activity Log shows all orders closed.
We need screenshots precisely showing what you are referring to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 12:57:41
[2021-03-02 01:38:47] |
When I flatten the position the position on the chart disappears but it shows a short position in the trades tab under Trade Activity Log. If I delete that trade in Trade Activity then the chart trade window position pops back up with a long position.
[2021-03-02 03:01:33] |
You need to make sure the Trade Activity Log and the chart are both using the very same Start Date-Time for the fills. Refer to: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-02 13:36:53] |
I couldn’t figure out how to find the chart fill time so I just deleted all the fills. Then I entered a new position and noticed the Trade Activity showed 2 fills instead of one. Is that what the linked documentation is saying about the very first trade in the Trade Activity Log? So pretty much ignore the first entry? I deleted the first entry and the chart trade position box came back on the chart.
