Date/Time: Mon, 24 Feb 2025 00:42:44 +0000
Big size of depth files (compression?)
View Count: 636
[2021-02-28 17:12:56]
User311344 - Posts: 142
Hey,
Loading/reloading charts with depth studies takes very long time. Esspecialy when chart is set to few days of data.
Is there any compression for depth files available and I should set it up somewhere? And would that increase chart loading time anyway?
My depth files are really big so no wonder it takes some time (0.5GB/day), but maybe theres something im not aware of as compression on the fly of those files?
Attached are sizes of my recent ES files.
Date Time Of Last Edit: 2021-02-28 17:13:52
Private File
[2021-03-01 05:27:20]
These files are compressed already. Compression is automatically enabled for those files.
Also update Sierra Chart to the current version.:
Date Time Of Last Edit: 2021-03-01 05:27:41
[2021-03-01 13:28:21]
User667154 - Posts: 10
automatically compressed? why ES 1,69 Gb. that's too much.
and manual compression does not work...
imagebandicam 2021-03-01 14-19-37-297.jpg / V - Attached On 2021-03-01 13:27:44 UTC - Size: 43.5 KB - 248 views
imagebandicam 2021-03-01 14-25-57-671.jpg / V - Attached On 2021-03-01 13:27:50 UTC - Size: 86.6 KB - 242 views
[2021-03-01 13:36:19]
The size you see in that screenshot, is the uncompressed size. If you look at the file Properties you can see the compressed size.
Date Time Of Last Edit: 2021-03-01 13:36:25
