Date/Time: Mon, 24 Feb 2025 06:30:27 +0000
Cumulative Delta and Bar Delta as part of the numbers bar
View Count: 728
[2021-02-28 05:27:01]
BAT - Posts: 33
How do I display the cumulative delta and the bar delta above / below the numbers bar - kinda like how it is shown on the attached screenshot please?
Thanks in advance.
imagecumulative delta and bar delta on the bar.PNG / V - Attached On 2021-02-28 05:26:36 UTC - Size: 191.65 KB - 224 views
[2021-03-01 00:04:30]
Refer to these studies:
Bar Delta Below Bar
Cumulative Delta Bars - Volume
[2021-03-03 00:59:45]
BAT - Posts: 33
Thank you - i got the bar delta to show up properly.. However, I am still not clear how to display the cumulative delta (since start of session) at the top of the numbers bar..
Appreciate any help.
[2021-03-03 14:45:16]
John - SC Support - Posts: 38116
You would need to use the Study Subgraph Above/Below Bar as Text study in combination with the Cumulative Delta. Refer to the following:
[2021-03-06 01:34:34]
BAT - Posts: 33
Thank you John - that worked.
