Date/Time: Mon, 24 Feb 2025 01:34:06 +0000
Unable to get historical data longer then a year.
View Count: 450
[2021-02-27 23:01:50] |
User558455 - Posts: 70 |
If someone can assist with historical data longer then a year. I use to be get data from 2011 on ES and still have the files in the data folder. I am only able to pull history till 2020-07-06 on most symbols. I had move from Denali to CQG however for feed, and recently went back to Denali however cannot pull older data. Thank you! |
[2021-02-27 23:58:51] |
Sierra_Chart Engineering - Posts: 18541 |
Make sure this option is enabled: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) And then refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
