Date/Time: Mon, 25 Nov 2024 19:52:59 +0000
SC on different partition
View Count: 1181
[2014-02-27 13:24:54] |
WarriorTrader - Posts: 245 |
Hello, Is it safe to install SC on a disk partition that is different form the c:\windows partition? Thx --WT |
[2014-02-27 15:34:39] |
Sierra Chart - Max - Posts: 5731 |
Yes it is safe. Sierra Chart does not need to be on the same partition as Windows.
Sierra Chart Support |
[2014-02-27 15:44:59] |
One more quick follow up: Can I just move the directory or should I install a fresh copy in the new partition? Thx, WT |
[2014-02-27 15:58:51] |
You can move the folder. Refer to help details 15 here: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html The most important item would be to make sure that Data Files Folder is properly set. Sierra Chart Support Date Time Of Last Edit: 2014-02-27 17:51:44
