Date/Time: Mon, 24 Feb 2025 06:16:02 +0000
Can I use my Sierra Charts subscription for a trading combine
View Count: 1452
[2021-02-26 21:20:25]
User715828 - Posts: 61
I am currently subscribed to the level 5 subscription through AMP futures using CQG and getting the reduced rate. I am looking to try and get funded by one of the companies such as Top Step One up, Leeloo, earn2trade etc. Can I hook them up to Sierra Charts to enter the trades for the Combine?
Someone told me it was better to subscribe directly with Sierra Charts and it would just cost a little more. I was also wondering if I should stick to the CQG feed? I heard Rithmic was having big problems.
I considering doing this quickly so I can start next month. Also, what are my options if I choose your Denali feed, will I still need CQG?, I'm only subscribing to the CME for the ES NQ futures.
Please let me know what I would need to do with you and AMP?
[2021-02-27 09:52:15]
binaryduke - Posts: 378
1. Nearly (probably every) evaluator uses Rithmic. You don't have a choice of Rithmic vs CQG during evaluation. If you get funded, potentially you do.
2. You can use Denali data (for reliability) combined with the Rithmic (paper trading) routing during the evaluation.
3. The SC license you take from AMP is constrained to AMP. If you want to do a combine evaluation, you will need to have a direct license from Sierra Chart.
so...
4. Stop paying AMP for SC.
5. Take out a direct license with SC. Sign up for whatever package you want including Denali data and the relevant exchange feeds.
6. Use the AMP platform setup form for your live account to request the CQG order routing for SC. NOT data. Just the routing.
[2021-03-01 00:46:29]
You need a direct account:
Notice: March/April 31, 2021 - Changes to Billing of Sierra Chart through Brokers
Direct Sierra Chart Account
When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below:
[2021-03-04 15:59:15]
Due to the changes with billing as explained here:
Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker
There is no longer a need for a direct account because all accounts at this time are now considered direct. This change will go into effect before the end of the day.
Date Time Of Last Edit: 2021-03-04 15:59:42
