Date/Time: Mon, 24 Feb 2025 04:29:52 +0000
Issue with Orders in sim mode
View Count: 558
[2021-02-26 14:51:32] |
User657945 - Posts: 226 |
Since I'm not more connected to TT/Orouting I'm using my autortading in sim mode on Eurex FGBL and from this morning I'm getting orders activatedf by Trading System alert condition in the opposite direction, also if the trading of that direction is set to NO in the studies. It never happened before in years. I'm on sc2226 since about 1 months no change made everything was fine. I got an long trade filled at 15.42 but if you look at the trade service log attached there's no trace of that order. Date Time Of Last Edit: 2021-02-26 14:52:03
[2021-02-26 15:15:11] |
and from this morning I'm getting orders activatedf by Trading System alert condition in the opposite direction This is impossible. We do not know how you are coming to this conclusion.also if the trading of that direction is set to NO in the studies. We do not know what this means.I got an long trade filled at 15.42 but if you look at the trade service log attached there's no trace of that order.
It will be in the Trade >> Trade Activity Log.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-26 15:15:30
[2021-02-26 15:48:00] |
Well I attached both trade activity log that shows the trade and the service log that do not shows the activation of the trade and you say This is impossible. We do not know how you are coming to this conclusion. , If the trading system based on alert condition is set to NO (not enabled) and it was workin gfdine till yeserday since years and today started to place order example long when the long setting ssay no which could be the conclusion?It's in SIM mode fortunately but in any case it's noisy since I use the signal to enter manually the order after the TT/AMP mess. |
[2021-03-01 23:48:06] |
If the trading system based on alert condition is set to NO (not enabled) So the Enabled Input is set to No?and today started to place order example long when the long setting ssay no which could be the conclusion?
We do not know what setting you are referring to. There is no setting like this.Examine the Trade Activity Log to see the behavior of the trading system: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 23:48:12
