Date/Time: Mon, 24 Feb 2025 01:30:34 +0000
No data on my charts
View Count: 422
[2021-02-26 14:12:48] |
JCROFT27 - Posts: 2 |
Hi there, I've uploaded a custom chart book but no data is coming up on my charts. Anything I'm not doing? Thanks |
[2021-02-26 14:30:59] |
John - SC Support - Posts: 38116 |
Most likely the Charts were from someone using a different service, therefore the symbols would be different from what you use. Select Edit >> Translate Symbols to Current Service after opening the Chartbook and this should resolve it. For reference, here is the command: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
