Date/Time: Mon, 24 Feb 2025 01:16:40 +0000
When using Trade Evaluator, AutoTrade System Replay BackTest is not working
View Count: 578
[2021-02-26 08:49:36] |
User317354 - Posts: 5 |
Hi, when the connection is Trade Evaluator (Delayed). Attempting to run Trade - AutoTrade System Replay BackTest will not have anything happen. The error in the Message Log is: Service client does not support enabling Trade Simulation Mode. Please help. |
[2021-02-26 15:05:03] |
John - SC Support - Posts: 38116 |
You cannot run a replay while having the service connected to the Trade Evaluator. Refer to the information here: Simulated Futures Trading Service: Using Internal Sierra Chart Trade Simulation Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-27 23:28:14] |
The documentation says "Therefore, it is not possible to use the internal Trade Simulation Mode when using these services unless you are doing a chart replay." But AutoTrade System Reply BackTest is exactly a chart reply Please help. |
