Date/Time: Mon, 24 Feb 2025 00:18:19 +0000
Package 3 for IB
View Count: 556
[2021-02-25 21:34:28] |
User379468 - Posts: 508 |
What's the reason users will not be able to purchase SC through a direct account on the original Package 3 to use with IB?
[2021-02-25 22:50:53] |
This is available. All of the available Service Packages are here: Description of Service Packages and Pricing: Packages How are you concluding otherwise? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-25 22:51:07
[2021-03-01 03:15:18] |
I was confused by posts about new changes removing historical data for CQG/IB users and also new requirements for CQG/IB users requiring Advanced package only, such as this one: SC staff plrease read. Future support for Interactive Brokers? So both Package 3 with IB Data, and Package 10 with Denali data will remain available for IB users? |
[2021-03-01 03:19:22] |
So both Package 3 with IB Data, and Package 10 with Denali data will remain available for IB users? Yes this is correct.
[2021-03-01 04:02:06] |
^That is good. 1. Does Denali data include the faster SC historical/intraday for SC/IB? 2. If also need IB data real-time to manage in TWS Mobile, possible to avoid double paying CME exchange fees twice, how? Can show already paying from trading account at IB? |
[2021-03-01 04:11:50] |
1. Yes, probably 100 times faster. Literally. 2. There is no solution to this. You have to pay fees twice in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
