Date/Time: Fri, 28 Feb 2025 04:30:14 +0000
Reporting 1 BUG
View Count: 636
[2021-02-25 21:16:37] |
GravisHTG - Posts: 306 |
On my computer - I open Chartbook 1 - with all chart detach already.( did not test if attach or detach change something ) Then I create a New Chartbook Then I copy all Chart from Chartbook 1 to new Chartbook with the Chart - duplicated all charts to chartbook options. Then I try to Save new Chartbook With Save As , cant save under a new name. Only think i can do to save under a new name is to Close chartbook then it will ask me to save , then i can choose a name. Thanks |
[2021-02-25 21:19:13] |
John - SC Support - Posts: 38259 |
Are you not able to select File >> Save As? Or can you select File >> Save As, but you can not change the name of the Chartbook in the Save As window? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-25 22:48:40] |
I can select Save As , but the Chart window to save never come.
[2021-02-27 20:14:46] |
this is now fix when i install the new version. Edit - I thought it was fix , no I make it bug again. - The video wont show the Menu but i can see it on my screen. look in this small video I recreate the Bug , I open 1 chartbook - can save as , 2 chartbook - can save as , 3 chartbook - can save as , 4 chartbook - can save as Then I open a new chartbook , Cannot save as. And can you see private video ? Date Time Of Last Edit: 2021-02-27 22:02:01
[2021-03-12 18:15:59] |
Sierra_Chart Engineering - Posts: 18594 |
This is still pending review.
[2021-08-11 12:47:59] |
This should now be resolved in the latest release.
