Date/Time: Mon, 24 Feb 2025 02:53:36 +0000
Chartbook - drawings not visible
View Count: 765
[2021-02-25 20:55:38]
User148541 - Posts: 2
Dear support,
I got some saved chartbooks from trader and when I open it in my SC I see only pure chart without aby additional drawings.
I attached the chartbook and also a printscreen what should be seen in a chartbook.
My settings in Chart -> Hide chart drawings - is unchecked.
thank you for your help.
BR
Vlad
Date Time Of Last Edit: 2021-02-25 20:56:04
Private File
Private File
[2021-02-25 21:16:16]
John - SC Support - Posts: 38116
We do not see any drawings in the charts that are in that Chartbook.
[2021-02-28 22:55:35]
You can see the drawings in Tools >> Manage Chart Drawings Window:
Chart Drawing Tools: Manage Chart Drawings
If that window list is empty, then there are none.
Date Time Of Last Edit: 2021-02-28 22:55:47
[2021-03-02 20:18:58]
thank you.
Tools >> Manage Chart Drawings Window: - I did not know about this feature this helped me a lot. I can check also other chartbooks
BR
Vlad
