Date/Time: Mon, 24 Feb 2025 12:28:55 +0000
Rejected Order
View Count: 2036
[2021-02-25 20:48:48] |
User53601 - Posts: 106 |
Hello, I tried to place Live order, but the Trade Service Log window pops up this mesage: Trading message from IB: The 'EtradeOnly' order attribute is not supported. Error Code: 10268. First time I got this message for last five years. Is there a way to get it work? Thank you |
[2021-02-25 23:00:12] |
Nothing has changed on the Sierra Chart side and that field is not used in Sierra Chart. Contact Interactive Brokers about this.
[2021-03-10 20:31:55] |
Hello, I have contacted Interactive Brokers, regarding this issue. I have got this answer to solve the problem: "may not have updated requests to no longer include this attribute when requesting data through api connection." Here is their error list: https://interactivebrokers.github.io/tws-api/message_codes.html Can you please check that. Thank you |
[2021-03-11 16:26:12] |
I was searching further and finaly found out the reason of the problem. I had the beta version of TWS (983+), this version is reporting that error. I have instaled the latest version of TWS and the problem has gone. Anyway, thak you for your time and support. |
