Date/Time: Thu, 19 Sep 2024 16:25:28 +0000
Pricing Eurex & CME feed
View Count: 1193
[2014-02-27 10:27:43] |
User31408 - Posts: 23 |
Dear all, Could you please tell me how much does it cost for a real time data on futures ? Eurex & CME ? (all in ) Could we have the equities with sierra ? Regards, |
[2014-02-27 10:32:01] |
For the Sierra Chart Real-time and Historical data feed, this will be about 65 USD a month. Equity/stock data, we expect will be available in about two months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 10:34:48] |
ok, thank you Have you got a bundle ? data feed + platform (MP,Vp & Fp)? Regards, |
[2014-02-27 10:42:45] |
Yes. The pricing for Sierra Chart itself can be found here: https://www.sierrachart.com/index.php?l=doc/Packages.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 10:43:43] |
no bundle ? data feed + Sierra chart ? |
[2014-02-27 10:47:53] |
The price for Sierra Chart and the data feed are separate prices. However, why should this matter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 10:49:18] |
ok, So to recap : 40 dollars for (MP,VP & Foot Print) + 65 dollars = 105 Dollars all in for the bundle Right ? |
[2014-02-27 10:59:20] |
Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 11:00:29] |
thank you for your help, |
