Date/Time: Mon, 24 Feb 2025 01:18:52 +0000
Plot Custom studies on top of charts
View Count: 487
[2021-02-25 17:46:44] |
InvestmentCLB - Posts: 11 |
When I create a custom study, how do I plot it on top of the chart and not in the subgraph? Thanks
[2021-02-25 18:03:52] |
John - SC Support - Posts: 38116 |
Refer to this setting: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) Within ACSIL the variable is the following: ACSIL Interface Members - Variables and Arrays: sc.DrawStudyUnderneathMainPriceGraph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-26 00:08:22] |
Hello, John. Could you show me an example code of how to properly use sc.DrawBaseGraphOverStudies = 1;
[2021-02-26 14:43:54] |
There are a few examples in studies8.cpp in the ACS_Source folder under your main Sierra Chart installation. Also refer to the following: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
