Date/Time: Fri, 18 Sep 2026 17:22:17 +0000
Monthly POC/Peak&Valleys/VWAP on a daily chart
View Count: 2695
[2014-02-27 08:54:12]
User41689 - Posts: 8
Is there a way to display on a daily/range/MN/etc chart, the MONTHLY POC, Peaks&valleys, VWAP, etc?
For example, looking at today's 4 range chart for the 6E, there would be a line on the chart displaying the Monthly 6E, VWAP, WVAP SD1, VWAP SD2, etc, as well as Monthly peaks & valleys, POC, etc?
This can be done by adding manually lines on a current chart for the appropriate levels found on a monthly chart, but is there a way to add this automatically?
Very useful feature.
[2014-02-27 18:54:24]
You need to use the following studies to get what you need:
Volume Value Area Lines
Volume by Price
Volume Weighted Average Price
Documentation for the studies can be found on this page:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html
You need to add the studies to the charts which have the chart bars set to the timeframe that you need them calculated on.
You can then overlay some of these to other charts as explained here:
http://www.sierrachart.com/index.php?l=doc/helpdetails28.html
[2014-02-28 09:55:04]
Strangely, altough the format seems to change, the actual name& value labels and positions ca not be changed in the new chart. For example if taking a 1 month vwap values and overlaying them on a 10mn charts, the labels and values corresponding to the 1 month vwap can not be changed (there is the option to do so but it won't work).
[2014-02-28 10:12:09]
Make the change to the study on the chart that contains the original study.
