Date/Time: Fri, 02 Oct 2026 17:52:17 +0000
Data Trade Service Settings
View Count: 748
| [2021-02-25 16:07:38] |
| wingz - Posts: 121 |
Since you've decided to change the Data Trade Service Settings window, out of the blue, can you please tell me how to change my service settings to another data provider, so I can fulfill my monthly requirement for Denali of connecting to another provider each month. When you make these changes, a "heads up" would be nice.
| [2021-02-25 17:32:36] |
| John - SC Support - Posts: 48091 |
The process is the same, but yes, the windows have changed. You will find the information for how to interact with the new windows here: Settings Windows Interface: Working with Sierra Chart Settings Windows The specific section to select a new service is here: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
