Date/Time: Mon, 24 Feb 2025 01:27:48 +0000
Nwe brokerage account
View Count: 476
[2021-02-25 15:23:18]
U993720 - Posts: 2
Hello Support Team,
I'm using Sierra with CTS! Now I need to a new broker and want to change to Sierra with Denali (and not routing through TT).
I think I need a brokerage account for Denali (->CME?)
Is AMP possible?
I'm absolutely unsure what is the appropriate way to go until Your routing is released.
Could You please help?
Karl
[2021-02-25 16:50:58]
John - SC Support - Posts: 38116
If you want to get the CME data at the Non-Professional rate, then you will need to have a futures trading account. Refer to the information here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
You can go with AMP, that is fine. They will set you up with CQG for the order routing. If you do this, then you would follow the Setup Instructions at the following link to connect Sierra Chart to your CQG account:
CQG Trading Platform Service
Another option would be to see if you can find a broker that supports TT and then you could use the Sierra Chart Order Routing Service. Refer to the information at the following link for this, and note a partial list of brokers at Step #2 of the Setup Instructions on this page:
Sierra Chart / Trading Technologies Futures Order Routing Service
