Date/Time: Mon, 24 Feb 2025 01:31:26 +0000
Hiken Ashi directly on a chart
View Count: 447
[2021-02-25 12:38:57] |
User266447 - Posts: 266 |
Dear Sir or Madam, How can I get Hiken Ashi directly on my chart. At the moment I have it on the bottom of my chart as an indicator. I would like to have it on the top of my chart as candles are (on the upper chart of a chart, not as indicators which are on the bottom of a chart). Please advice. Kind regards, Arek |
[2021-02-25 14:01:22] |
You need to activate this setting for the study: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
