Date/Time: Sat, 19 Sep 2026 02:03:37 +0000
6T?##-CME South Africa Rand missing under CME Futures (Realtime)
View Count: 888
| [2021-02-25 08:08:34] |
| PH123 - Posts: 5 |
Hello folks, On my terminal, I have been looking for the below CME Futures symbol which appear to be missing despite being announced under CME symbol list: Description: South African Rand Symbol: T6 I could not find: 6T?##-CME South Africa Rand This futures contract is listed under available CME Exchange symbols in Sierra Data Real-time document: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#cme Would you be able to let me know what should I do to have this symbol appear on my Sierra terminal please? Kind regards, |
| [2021-02-25 09:05:41] |
We have now added this symbol. You will see it listed as 6Z?##-CME Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-25 09:17:14] |
| PH123 - Posts: 5 |
Thank you team. Would it be possible to update USD/ZAR symbol too please as it is not showing under CME? Description: USD/ZAR Symbol: T3 Date Time Of Last Edit: 2021-02-25 09:21:20
| [2021-02-25 09:21:44] |
We do not see that product listed on the CME website. If you can find it for us, we can add it. The Barchart symbol you show, is not what we work with any longer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-25 09:21:57
| [2021-02-25 09:29:53] |
| PH123 - Posts: 5 |
Hi team, here is the link for the USD/ZAR futures contract of CME: https://www.cmegroup.com/trading/fx/emerging-market/usd-zar-south-african-rand.html |
| [2021-02-25 09:45:26] |
What is the purpose of adding this. The symbol does not even trade.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-25 09:45:32
| [2021-02-25 09:57:58] |
| PH123 - Posts: 5 |
I would have expected USD/ZAR future to be traded as it is listed by CME. If it is not traded, I will handle Rand future only. Appreciate your prompt support for the symbol maintenance earlier, thanks. |
