Date/Time: Wed, 26 Feb 2025 18:03:28 +0000
T Bonds June Contract
View Count: 539
[2021-02-25 05:29:42] |
User90927 - Posts: 38 |
On the 4 hours and 1 hour charts for ZBM1 the data only begins from 21 Feb 2021. I am with Transact could you resolve this issue? |
[2021-02-25 11:53:53] |
We are in the process of phasing out support for Transact. Please begin to use the Denali Exchange Data Feed: Denali Exchange Data Feed This will completely replace the Transact data feed. Let us know if you need help getting set up with the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-25 11:54:01
[2021-05-28 11:43:58] |
Again same problem.Timeframe from 4 hours down to 5 mins on the rollover contract for Sept. T Bonds the data is only showing from 27 may ie a day. So really there is no chart to look at. The daily contract is ok as it is showing data from 24 March 2021 |
[2021-05-28 14:24:44] |
John - SC Support - Posts: 38206 |
We can not help you with the TransAct data. You really need to use the Denali Exchange Data Feed for the CME Group data. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
