Date/Time: Sun, 23 Feb 2025 22:37:37 +0000
line chart
View Count: 638
[2021-02-24 21:25:06] |
User788130 - Posts: 5 |
i do need intraday line chart, which is not the line on close u offer unless the time selected is close to zero (but can i put 0.000001 ms? no) i need the most simple classic line chart u get from yahoo, google finance etc.... in other words... a line chart intraday that at any point in time plots the price of the transaction buy-sell happening. i dont even know how to describe it as for me a line chart was just that until i came across u line on close honestly
[2021-02-24 21:28:26] |
John - SC Support - Posts: 38116 |
What you are describing is a Line on Close chart. That is what you see when you look at a chart from online sources. The most recent point will reflect the current price.
[2021-02-24 22:02:16] |
Ackin - Posts: 1865 |
select Chart >> Chart Settings. In the Graph Draw Type box, select the "Line on Close" Graph Draw Types: Line on Close |
[2021-02-25 13:16:58] |
Relevant documentation is here: Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
