Date/Time: Mon, 24 Feb 2025 00:54:26 +0000
Line on Close
View Count: 961
[2021-02-24 21:03:11]
User788130 - Posts: 5
hi. okay... i already askeed cannon to close everything but i will put on hold my request for today waiting for u guys.
i do need intraday line chart, which is nto the line on close u offer. i need the most simple classic line chart u get from yahoo, google finance etc.... in other words... a line chart intraday that at any point in time plots the price of the transaction buy-sell happening. i dont even know how to describe it as for me a line chart was just that untill i came across u line on close honestly
if u can give me precisely that i will stay otherwise no reason.
thank you very much please try to respond today
alberto
[2021-02-24 21:22:27]
John - SC Support - Posts: 38116
If you are just looking for a Line on Close chart, then open a chart for the symbol you want and select Chart >> Graph Draw Types and select Line on Close.
Refer to the information here:
Chart Menu: Graph Draw Types (Chart menu)
[2021-02-24 21:31:23]
john letz make an example. say my focus is 60minutes window
the line chart u offer is line on close.
say i select 10minutes as interval on it
that means that over the 60minutes i get 6 only plots in the chart, specifically first at 10min with the price at that moment, the second at 20min with the price at that moment and so on. okay.
from one point to another there is an extrapolation or whatever.
i am saying now that i want/i need real pricing on the chart not every 10minute, but at each tick, at each transaction. .... sometimes two trade can be a fraction of second apart, other times more. how do i get this? can i put in the line on close 1ms as time? this is my question which i dont think i am able to comunicate dontn know why
thx
[2021-02-24 22:57:03]
Use either of these two data feeds:
Denali Exchange Data Feed
Delayed Exchange Data Feed
[2021-02-25 14:49:41]
If you want to see every trade, then you would set your Bar Period to be Number of Trades and then set the number of trades to 1. You would make these changes in Chart >> Chart Settings. Refer to the information at the following link (and the section immediately after it):
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar
