Date/Time: Mon, 25 Nov 2024 19:34:38 +0000
[User Discussion] - Numbers Bars
View Count: 1144
[2014-02-27 04:28:34] |
Fxxtrader - Posts: 79 |
Volume Percentage Coloring | Trades Percentage Coloring Hi, regarding this description here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#VolumeTradesPercentage and here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ColumnCompareThresholds How is the colour shading determined? At each price level, if ASK is > than BID then the colour shading is green? Of these four categories, which one represents the shading with the highest volume/trade? Which one represents the the shading with the least volume? A)Up 76-100% Color B)Up 51-75% Color C)Up 26-50% Color D)Up 0-25% Color And how does it relate to the selection made background colouring method? Same for the Down color options. Note: I think Up 76-100% Color colours the level with the highest volume/trade, while Up 0-25% Color colours the level with the lowest volume/trade for the entire bar, right? Thanks in advance. |
[2014-03-04 00:50:52] |
The documentation does explain all of this. Or your questions are outside the scope of our support.
