Date/Time: Mon, 21 Sep 2026 03:18:17 +0000
CQG data ( Package 5 ) or Denali data without TT
View Count: 869
[2021-02-24 21:02:12]
User931436 - Posts: 3
Since TT has a problem with CME, so should I change back to use CQG Data package 5 or use Denali Data without TT? Please advice?
[2021-02-24 21:15:02]
John - SC Support - Posts: 47939
You should continue to use the same package and data as you have been. Just change the order routing from TT to CQG.
[2021-02-25 16:36:02]
How to do it?
[2021-02-25 17:34:02]
AMP should have changed you to CQG order routing. If not, then get with them about making this change. Then follow the instructions at the following link:
TT Based Order Routing Service: TT Interruption | Post: 252374
