Date/Time: Sun, 23 Feb 2025 22:50:59 +0000
Dorman TT and Sierra Chart Futures Order Routing Service with Data
View Count: 605
[2021-02-24 20:12:56] |
GreyLock58 - Posts: 170 |
In a past post, I believe that Sierra Charts stated that they have an account with Dorman. Did Sierra Charts use TT with Dorman and was there a problem like there was using TT through Amp? If I move my account to Dorman will I be able to set up in the same way I was with AMP? That is to say Denal data feed using Sierra Chart Futures Order Routing Service via TT? |
[2021-02-24 20:25:49] |
John - SC Support - Posts: 38116 |
Yes, you can use Dorman with the Sierra Chart Order Routing Service.
[2021-02-24 20:39:16] |
Understood, but did Sierra Charts have the same issues with TT through Dorman?
[2021-02-24 21:07:35] |
The issues that TT had affected all trading with TT, including Dorman. But, once TT had their issues fixed on February 16, 2021, things went back to normal for most brokers. AMP decided to pause trading for a longer period as they felt they had additional issues they needed to resolve, and then decided to not support TT anymore. That is where things diverge. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
