Date/Time: Mon, 24 Feb 2025 00:53:15 +0000
PRICE OF SIERRA AND CME
View Count: 645
[2021-02-24 19:16:31] |
User539608 - Posts: 4 |
Salah tataouine 06:44 (il y a 13 heures) morning all i see i have to pay 76.2 $ is it for only this month february 02/21 or for a month it s means until 24 OF mars because month 02 was paid or have i t or have i to wait till the end of this month to pay MARS thank you Salah tataouine <salahhamzii@gmail.com> 07:23 (il y a 12 heures) À Sierra sorry i forget something can i pay directly from my broker as us |
[2021-02-24 19:57:51] |
John - SC Support - Posts: 38116 |
The $76.20 you owe will be taken from your Services Balance on March 01, 2021, as this is for the Denali Exchange Data Feed, which renews on the first of each month. It is possible to have your Denali Exchange Data Feed fees paid through your broker. You would need to talk to your broker about this and have them make the change for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-25 19:14:29] |
hello here is the answer from my broker Max Rathberger (AMP Global (USA)) Feb 25, 2021, 10:34 AM CST Hello Mohamed, OK - we'll make sure to disable the data enabled on the CQG user at the end of this month. You will, then, need to request the following via the Live Trading Set Up request form- https://clients.ampfutures.com/live-trading-setup-request : You would, then, enable Denali data with Sierra Chart. Regards, Max Rathberger |
