Date/Time: Sun, 23 Feb 2025 22:23:25 +0000
Chart DOM (Bid-Ask) Market Depth Pulling/Stacking Volume Bar
View Count: 1440
[2021-02-24 19:03:56]
Sudhirc - Posts: 54
Chart DOM Bid Market Depth Pulling/Stacking Volume Bar &
Chart DOM Ask Market Depth Pulling/Stacking Volume Bar
Both above features can be drawn on DOM as shown on the attachment, -- but could not activate on Chart, How can i get Volume Bars on charts as well?/
Date Time Of Last Edit: 2021-02-24 19:04:39
imageSierra.JPG / V - Attached On 2021-02-24 19:02:59 UTC - Size: 133.87 KB - 405 views
[2021-02-24 19:48:35]
John - SC Support - Posts: 38116
You have to make sure you are setting the items for the Trading DOM itself. It is it's own chart, therefore, it has it's own set of controls. To begin with, you would need to select Trade >> Customize Chart/Trade DOM Columns on the Trading DOM, and then select the option for Show Volume Bars for the particular column(s) you want. Refer to the information here:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
If you want to change the color for the Trading DOM Pulling/Stacking Volume Bar, then you would either need to do this from the Global Graphics settings (Global Settings >> Graphics Settings), or from the chart specific Graphics Settings, if that is preferred (on the Trading DOM select Chart >> Graphics Settings and deselect the option for "Use Global Graphics Settings Instead of These Settings"). Refer to the information here:
Graphics Settings
