Date/Time: Thu, 19 Sep 2024 16:21:43 +0000
User Email Question
View Count: 1107
[2014-02-27 04:21:39] |
Sierra Chart - Max - Posts: 5662 |
Hi.
I'm having a problem with the data on the DOW market profile chart. All the other indexes work fine in all time frames. I have tried everything. I have been using MP for a long time. I don't think I am doing anything wrong. Here is the problem: I am getting only a single print (the letter N) for the entire 24 hour DOW session. The other time frames are ok. The pit session works fine. It just started happening out of the blue. I never have had a problem like this before. The other indexes work fine. I haven't changed any settings. How do I fix this! Go to Chart >> Chart Settings. Press the Apply Global Symbol Settings button. Press OK. See if that corrects the problem. Otherwise, we will need to see an image of the chart by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image To reply you will need to create a Sierra Chart account as is explained below: https://www.sierrachart.com/index.php?l=PostingInformation.php Sierra Chart Support Date Time Of Last Edit: 2014-02-27 18:22:35
