Date/Time: Sun, 23 Feb 2025 22:52:38 +0000
I want to link my account with AMP future too. Is it possible ?
View Count: 477
[2021-02-24 18:55:19] |
GravisHTG - Posts: 306 |
I know that i will need to get 2 Different Main Running. 1 Will be for Interactive Broker for Options and Stock The other will be for : Amp Future for FUTURES. I check the data feed, but i could not find AMP futures. What I will have to do to be able to trade futures with them on my account that i already have. Thanks in advance. |
[2021-02-24 19:42:01] |
John - SC Support - Posts: 38116 |
Have you established an account with AMP yet? If so, then they should have given you credentials to connect to CQG. You would then install a second installation of Sierra Chart, per these instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart And then you would setup that new installation to connect to those CQG credentials using these instructions: CQG Trading Platform Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-24 19:49:43] |
Ok , I will get an account when I am ready. thanks for the information. |
