Date/Time: Sun, 23 Feb 2025 22:56:17 +0000
CQG pricing
View Count: 465
[2021-02-24 15:19:12]
User488155 - Posts: 8
Because of the problem with TT routing, I have switched to CQG routing.
Will I be charged through Sierra Chart or AMP for the CQG routing?
What are the costs for CQG routing through Sierra Chart?
I see that CQG is labeled as inferior to TT insofar as delay and accuracy of routing for the trades. I was with AMP futures using CQG before, and knew of no problems. Can you explain if there are still problems with CQG routing with Sierra Chart, and if no delays and now considered OK, why is the detrimental information still on this site regarding CQG? This is negative information very unsettling, and makes me wonder if I should still use CQG through Sierra Chart. Please help.
Barbara Arnello
[2021-02-24 16:51:27]
John - SC Support - Posts: 38116
You will be charged through AMP for the CQG routing.
You need to ask AMP this question.
Due to the connectivity method between Sierra Chart and TT and Sierra Chart and CQG, the order processing is going to be slightly longer with CQG, but we are still talking about fractions of a second.
