Date/Time: Sun, 23 Feb 2025 21:38:34 +0000
Data Feed Not Working
View Count: 433
[2021-02-24 15:16:12] |
User433223 - Posts: 1 |
Hello, I am using the delayed data feed for futures (MESH21), and it is not working properly, as of this morning. Please advise. Thank you, |
[2021-02-24 16:39:33] |
John - SC Support - Posts: 38116 |
We are not seeing any issue with the data feed. The first thing to do is to select Edit >> Translate Symbols to Current Service. This will ensure that if there are any old symbols in use that they are updated to the proper naming convention. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
