Date/Time: Sun, 23 Feb 2025 22:08:35 +0000
CQG
View Count: 453
[2021-02-24 15:11:38] |
User318521 - Posts: 47 |
I tried to log in to CQG because i would like to switch from TT and it says login disabled and to contact your FCM. Is that sierra chart?
[2021-02-24 16:05:46] |
John - SC Support - Posts: 38116 |
Assuming that you have gone through the Setup Instructions to connect your Sierra Chart to CQG, then that message would be from CQG. Refer to the information here: CQG Trading Platform Service: Common Error Messages Also refer to the CQG Setup Instructions here: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
