Date/Time: Sun, 23 Feb 2025 22:04:51 +0000
EUREX and depth data backfill
View Count: 520
[2021-02-24 09:02:01] |
User365411 - Posts: 192 |
Please, can you confirm that, for the delayed SCdata feed, the market depth data backfill for EUREX is currently NOT available? And if and when it will be released? I can see it only when I'm connected. All it's ok with CME feed. TY |
[2021-02-24 12:55:13] |
It should be available but we have not tested this. We will work on that today.
[2021-02-24 13:28:09] |
We will make the historical market depth data for EUREX available in about 20 minutes.
[2021-02-24 13:47:04] |
There is more work we need to do regarding historical market depth data. We need to work on this over the weekend. We will start EUREX historical market depth data as of tomorrow, but the prior data which we have has to be copied from another system and we can only do that on the weekend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-24 13:49:31] |
OK, take your time, no problem, thanks for the feedback. TY |
