Date/Time: Sun, 23 Feb 2025 22:39:52 +0000
Received Order Status with transaction_status_size = 0.
View Count: 461
[2021-02-24 04:02:51] |
seandunaway - Posts: 331 |
I get these each night. Are there any adjustments I should make on my side or are these safe to ignore?
Date Time Of Last Edit: 2021-02-25 00:05:37
[2021-02-24 20:57:32] |
Not sure what to say about this. Other than to say it has to do with the behavior of the CQG system.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-27 07:49:04
